Wiring woes....
Car: 1994 Jeep Wrangler
Wiring woes....
Anyways, I won't get into the details of the story as it is not relevant, so to make a long story short, I pulled my wiring harness out. Then I re-installed it. Now the car will not do anything when I put the key in. If I shake the wiring that goes behind the engine, somtimes i can hear the buzzer for a short time if i leave the key in. But it quickly goes away. Am i right in assumeing that this is a problem associated with the accecory wiring that enter the the car thru the driver side firewall and not the ecm/ FI part of the harness? Anybody have any specific tips or specific conections I should start with? of should I just slowing look through all of the wiring again
Car: 1990 Camaro
Engine: 3.1L
Yes, the problem is that the bulkhead connector is not tight. You have to make sure that the 1/4" bolt in the middle of the connector is tightened in all the way and that there are not any wires behind the connector that are keeping it from being tighten down all the way.
Glowsock
Jan 9, 2017 04:06 PM
