quick smog electronics
Old Jul 24, 2006 | 10:34 AM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
What fuse is the smog pump electronics on? Are their any relays for smog pump operation? I'm thinking of adding an addition heated 02 off one set of the smog pump connections. One of the two wires is black with pink stripe, so its 12v+. Any problem with this?
Old Jul 26, 2006 | 12:36 AM
Car: 91 Camaro RS
Anyone ever looked into anything similar to this?
Old Jul 26, 2006 | 10:11 AM
Car: 91 Camaro RS
Looks like it runs off the gauges fuse which is 10 amps. Would adding a heated o2 be too much draw?
Old Jul 27, 2006 | 08:24 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
No not at all..
I never saw spec.s for heated O2 nor have I measured one, but it would draw something in the neighborhood of 100 milliAmps..
Even if I'm wrong with a factor of 10 it would still be safe..
jaridjohn
Oct 5, 2015 07:01 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
