fan switch wiring?
Old Aug 11, 2006 | 04:35 AM
BADASS91B4C's Avatar
Car: 1991 B4C, 1992 RS
Engine: 355, 305
Transmission: 700r4, 700r4
Axle/Gears: 3.73, ?
fan switch wiring?
ok so the fan switch sensor on the passenger head, what do the grey wires that run from the sensor go to? i need help wiring this uo any info would be awesome. thanks!
Old Aug 11, 2006 | 09:05 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
The grey wire goes to the aux fan relay on the firewall (driver side). It is probably spliced in the harness and goes to the A/C pressure switch.
Hope this helps.
Lou
Old Aug 11, 2006 | 03:24 PM
Engine: 355, 305
Axle/Gears: 3.73, ?
ok cause i switched to a comander 950 and removed my a/c so there is two wires running out of the sensor both are grey one goes to the fan relay right? and the other goes to nothin cause i no longer have a/c, correct?
Old Aug 11, 2006 | 03:38 PM
BigBadLou's Avatar
Engine: TPI
You got it!
Old Aug 12, 2006 | 01:22 AM
Engine: 355, 305
Axle/Gears: 3.73, ?
awesome thanks man!
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
TA8487
Aug 16, 2015 12:21 PM
