Original vss needed?
Old Aug 14, 2006 | 05:02 AM
alicat's Avatar
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
Hi all,I'm putting in a Autometer electronic speedo,and since my car had a cable driven speedo,i'm using autometer's sender on the tranny.Does anyone know if the original vss buffer has to be used as well as the new sender.The new speedo has a out terminal which could take the signal to the ecm and cruise control,but i dont know if i still need to use the vss buffer to correct the signal out from the new sender.The car is a 85 Z28.I've done lots of searches but have'nt found the right answer.Can anybody help with this?
Thanks,Alicat.
P S,Mods,If this is in the wrong board please move.
Old Aug 14, 2006 | 06:44 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
The vss uses an infrared LED and a phototransistor. The vss buffer supplies the correct current to the LED and amplifies the (weak) phototransistor signal to a well defined 5V digital logic level.
If the Autometer sender has a 12V input, and an output giving a 5V logic level signal (i.e. has a built-in buffer meant to be connected direcly to an ECM) then you would not need the old vss buffer. You should then disconnect the old vss buffer so you don't get two outputs fighting each other.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
