Power trunk release and pull down
Old Aug 20, 2006 | 01:14 PM
fastfirebird's Avatar
Car: 91 Firebird Formula,2 1979 T/A's
Engine: 5.0 TPI, 403
Transmission: 700r4,turbo 350
I have a 91 Formula that has the old style ( metal bracket) pull down. I have aqquried 2 pull downs from a 92 firebird and a 92 camaro plastic bracket is there anyway to connect the plastic one to my car? Or if not is there a way that I can test these plastic one to make sure the work? Thanks for any help you can give.
Old Aug 20, 2006 | 01:30 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
I did renforce my old ones.
You could measure were the old one stops pulled dawn(you can push with a screwdriver to activate the pull down swith).
Then you mount the new one and check if it stops and fits in the same position as the old one. If not find a way to adjust it.
***only if everithing is in the right position you can close the hatch if not renforce the old one and put it back on***.
Vintageracer
Jan 10, 2020 05:33 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
neekolzun
Aug 24, 2015 04:59 PM
stalkier
Aug 21, 2015 01:54 AM
smooth
Aug 18, 2015 06:34 PM
