Light problem
Old Aug 21, 2006 | 04:07 PM
beady's Avatar
Car: 1990 Camaro
Transmission: 4L60
Light problem
Ok replaced my HeadLight switch did not correct this problem, When I turn my headlights on seems that with
the dash lights illuminated the guages all shut down, The gas guage goes to empty, the tach goes past redline and stays, the amp guage functions only. This car has the
ECM removed as it is now a Carb 350 engine. any thoughts
or things to try ?...Checked all the grounds and all good.
Old Aug 21, 2006 | 04:36 PM
1bad86's Avatar
Car: 1986 IROC-Z
Engine: 305 T.P.I.
It's a pretty common problem mine is doing it too.... You might want to take the gauges out and look for breaks in the Printed Circuit Board on the back.
Old Aug 21, 2006 | 04:41 PM
beady's Avatar
Car: 1990 Camaro
Transmission: 4L60
Had that out and all are looking good, even tried another
guage cluster, same thing.....
Old Aug 21, 2006 | 04:46 PM
1bad86's Avatar
Car: 1986 IROC-Z
Engine: 305 T.P.I.
dangit I just bought a new cluster off ebay....
Old Aug 21, 2006 | 09:48 PM
beady's Avatar
Car: 1990 Camaro
Transmission: 4L60
electric
right now I tend to think that by the Sirs system using the guages fuses as well as thier own it might be a overdraw on
the headlight switch causing a power drop but will test
further and see where that leads too..
Old Aug 23, 2006 | 11:00 PM
beady's Avatar
Car: 1990 Camaro
Transmission: 4L60
Lights
TTT Anyone have thoughts ????
TheJoeY88
Dec 31, 2016 07:30 PM
DiabolicalRS
Aug 26, 2015 07:35 AM
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Omega
Aug 10, 2015 12:46 PM
