cigarette lighter not working correctly
Old Aug 24, 2006 | 05:30 AM
Camas_Camaros's Avatar
Car: 1988 Camaro RS/1983 camaro z28
Engine: V8 305 L69
Axle/Gears: 2.73 posi
so i have a 1989 formula firebird that has a cd player that doesnt work in it so all i have is the radio and i have a monster icarplay (bought to use in my other cars ive had it a while) it worked perfect for me for a day, then when i was taking a buddy of mine to the airport all of the sudden it just stopped working. i can plug it in and get the light on the male connector to turn on but nothing from the rest of the icarplay or anything else i use in my cigarette lighter for that matter. so i guess my question is since i know its getting power could it just be the ground thats acting up on me? and if so where should i reground it (maybe on the cd players ground?) i just want to not have to listen to the radio with out spending the 100 dollars for a new cd player or tape player. any help is appreciated thanks.
Old Aug 24, 2006 | 04:09 PM
Engine: V8 305 L69
so no one has anythoughts on this at all?
Old Aug 24, 2006 | 04:23 PM
2kflhr's Avatar
Car: '68 396 SS/RS, '02 SS
My suggestion would be to plug the acc. back into the lighter outlet and wiggle it around to see if the light stays lit or flickers. If it flickers I would check the connection at the back of the outlet. The connection can work loose from plugging and un-plugging the lighter and other accesories into it.
Old Aug 24, 2006 | 05:02 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Try something else in the cig lighter to see if it is working. If not I would just plan on replacing the lighter socket, really easy to do. If it shorted out there is a reason why and it may effect other items. And finally I would get the CD player working properly.
Old Aug 24, 2006 | 11:27 PM
Engine: V8 305 L69
ok so if i jiggle it the light does flicker and such, so that means there is a short in cigarette lighter plug so that means i need to replace it, so heres the question how the **** do i get it out with out having to break it out of the plastic? and i can get the replacement at like radio shack or shucks right? thanks
and i the stereo works good but when i put in a cd the motor just doesnt engage and spin the disk. so it needs to be replaced (either the unit or the motor to the spindle).
Old Aug 25, 2006 | 12:03 AM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Seriously, DONT TOUCH ANYTHING, bro take your car to a pro before you burn it to a pile of worthless metal and plastic!
Old Aug 25, 2006 | 03:18 AM
Engine: V8 305 L69
ok so nows where i get slightly offended. im not stupid enough to burn up my car with an electric problem. the only problem im having is that i cant get the acctually plug out of the center console after disconnecting the postive and ground. i mean honestly this is the only problem with my car ive needed help with. i just dont how the to remove the connector from the center console once i have the center console out and completely disconnected. if anyone can riddle me that ill thank them. thats the only problem i have right now other than that im good(adjust my timing to day to make her run like a dream again and she does).
Old Aug 25, 2006 | 05:54 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
IIRC, the cigarette lighter problem is fairly common. You might consider a .
JamesC
Old Aug 25, 2006 | 11:01 PM
Engine: V8 305 L69
fixed it today, seems that there was a bunch of ash and rust keeping it from unscrewing. but i got it. thanks for the help guys. and for those who think i should have takin it to a professional, im no newbie at cars so **** it.
Ghettobird52
Jul 5, 2024 11:18 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Linson
Aug 21, 2015 02:12 PM
Vintageracer
Aug 11, 2015 08:13 PM
apie2546
Aug 8, 2015 07:12 AM
