help? troubleshooting electrical misfire after an hour
Old Aug 27, 2006 | 11:57 AM
valencia1z's Avatar
Car: 1986 IROC-Z
Engine: 350 5.7 TPI
Transmission: 700R4 2500 stall
well here it is its a 86 iroc-z tpi big cap distributor with 7 pin module for some reason once it heats up or driven for about 30-45 min and it gets real warm it will not want to idle and it misfires all over i was thinking it was in the ignition so far the coil and ignition module have been changed and still acting up after u let it cool off pretty good its back to normal im stuck, any sugestions ? it does it more during the day when its hotter not so much at night depending on the temp im stuck here guys .
Old Aug 27, 2006 | 07:58 PM
jamessr's Avatar
Car: 92 Firebird
Engine: 5.0L V8
Transmission: 700-R4
Have you pulled your spark plugs and looked at the condition of them? Also when is the lats time they been changed? If your going to pull them to check em, might as well have a new set on hand to change em if needed.
For now though check the conddition of your plugs
SRKLEGIN
Oct 29, 2015 06:38 PM
school boy
Oct 22, 2015 11:47 AM
NZKnight
Oct 15, 2015 02:47 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mfp189
Sep 27, 2015 09:25 AM
