i have no injector pulse
Car: 1989 iroc z
Engine: 5.7
Transmission: t 5
i have 1989 iroc 5.7 tpi it will not start .i have spark to the plugs,fuel pressure to the fuel rail,but no pulse to the injectors.i am using a noid light to check the injectors any help or ideas would be great thank you
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Do you have 12 volts to the wires with the key on?
If not check fuses.
If you do, then it could be the ign. module.
Also check all connections on the ECM and Memcal.
If not check fuses.
