Need serious help with Tach hook up
Old Sep 6, 2006 | 06:00 PM
XxGeinNothingxX's Avatar
Car: 1991 Camaro RS
Engine: 350 bored .30 over
Axle/Gears: Posi 342
I have a external coil, I need to know where to put the green aftermarket tach wire. I think I might have an idea. The coil has two I guess inputs. A white one on the left and a black on the right, each with two wires. Do I need to splice into the back wire on the left side(white terminal)? IF no, what do I do or where could I look to find this out.
Old Sep 7, 2006 | 05:25 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
On the white/gray connector if you follow the white wire it shoud lead to a connector. If you are not going to use the stock tach unplug this conncetor and connect your green wire to the connector on the coil side.
Old Sep 8, 2006 | 02:55 PM
Car: 1991 Camaro RS
Hey man, I appreciate you trying to help but I already have it all hooked up. I ended up splicing into that negative coil wire between the coil and that plug ur talking about. I had no clue that was a tach deal. My stock one is still going, reading idle at 3.5k. Lol, why in which I got the aftermarket. Thanks though man. Do you think I could still unplug that and everything would funcion correctly the way I have it set up?
Old Sep 8, 2006 | 05:36 PM
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Everything execpt the stock tach. Mike
$750 L98
Feb 1, 2025 02:25 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
Gordonr1973
Sep 29, 2015 11:59 AM
Eric-86sc
Sep 28, 2015 11:37 AM
