headlight motor R&R
Old Sep 14, 2006 | 06:36 AM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
headlight motor R&R
so i got a helms manual finally.... but now I need to take out my headlight motors so i can better access the wiring, and I've forgotten how i did it the first time. anybody got any ideas? or does this require 2 days and a complete removal of the bumper? or if you know where to find it in the manual, i have it here at work, and i'll read how they say to do it.
Old Sep 14, 2006 | 08:56 AM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
Removing the entire headlight bucket, with the motor attached, is the easiest and quickest way I have used. The two bottom bolts on the bucket are easier to reach from underneath the car after removing the splash panel.
Old Sep 14, 2006 | 09:48 AM
Car: 1982 Trans Am
Engine: 383 chevy
ok. I can do that. I'm going to basically be rewiring them, as they don't seem to be working at all, and I've replaced the switch, all 3 relays, and the motors themselves. i had a problem with the left HL being dim, so i fixed the ground and it works better. the other light is bright and normal, but the motors don't go up and down. I figure the best thing is to grab a test light and test for power on the appropriate wires using the manual. ARRGH. frickin wiring.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
GTAman
Mar 15, 2019 11:40 AM
LittleFranks
Sep 17, 2015 12:22 PM
stalkier
Aug 13, 2015 12:59 PM
