Problem removing the battery
Old Sep 14, 2006 | 05:51 PM
RedL98's Avatar
How do I remove the battery if the bolts on the terminals are stripped?
Old Sep 14, 2006 | 06:08 PM
CF86SC's Avatar
Car: 1986 SC Camaro
Engine: 5.0
LOL vice grips
Old Sep 15, 2006 | 03:56 PM
rhomanski's Avatar
Car: 86 firebird v6,86 corvette,88 GTA
Engine: 350 C.I.,2.8l.
Transmission: th700r4
Axle/Gears: 3:08,3:27
I used channel lock pliers when mine stripped.
Old Sep 15, 2006 | 04:03 PM
reddog85z28's Avatar
Make sure you get the ground loose first in order to avoid shorting it out.
Vice grips are my second choice now that I got the "sockets" from Sears for removing stripped bolts, they work like a champ.
Old Sep 15, 2006 | 04:47 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The battery terminal bolts are so soft you'd probably only end up sharpening them if you tried those.
Frozer!!!
Jan 19, 2024 04:55 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
justin57
Aug 20, 2015 07:05 PM
3rdgenparts
Aug 8, 2015 07:09 PM
