rear defroster problem
Old Sep 15, 2006 | 10:36 AM
red90bird's Avatar
Car: 1990 Firebird
Engine: LS3
so as the title says my rear defrost dosen't work and I've finally found the motivation to fix it. the grid is good, the switch seems to be good and power is getting to the switch (only on one prong though). all the fuses under the dash are good; however I think I read somewhere that the defroster is fused in a different location. anyway where should I go from here???
yeah I know I haven't posted in a while but I've been searching and lurking
Old Sep 18, 2006 | 08:45 PM
red90bird's Avatar
Car: 1990 Firebird
Engine: LS3
bump
Old Sep 22, 2006 | 08:07 PM
Stealthy-One's Avatar
Car: 89 RS
Engine: 2.8
Transmission: 700r4 auto
Axle/Gears: huh?? guessing stock.
sorry I cant help you, but what do you men by the defroster is fused somewhere else? maybe that is my issue as well.
Old Sep 22, 2006 | 08:14 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
power comes from the power accesory circuit breaker and the gauge fuse.
Old Sep 23, 2006 | 03:28 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
If you remove the piece of dash with the defroster switch, you'll see a 6-prong connector on it with 5 wires. Check the following wires:
- orange/black - should have 12V on it at all times
- pink/black - should have 12V with key on
- gray - should have 12V with lights on (doesn't matter right now)
- blk - should be grounded at all times (measure against 12V)
- purple/white - should seem like it's another ground (measure against 12V again)
If all this checks out, follow below:
- key off - confirm that the purple/white wire shows 12V if you measure it against 12V. If not, the circuit to the defogger is bad.
- key on - confirm that the purple/white gets 12V when you activate the defogger. If not, the module is bad.
- key on - activate the defogger and confirm that the ON indicator is lit. If not, the module might be bad.
Let us know what you find.
Hope this helps.
Lou
Old Nov 1, 2006 | 11:30 PM
beautysMistress's Avatar
Car: 83 Trans Am
Engine: 5 L
Transmission: Automatic
Hello, I have similar problem. Rear defroster doesn't work.. I pulled the switch and wire colors are as above except there is no orange wire. Instead I have a light blue one. I did have juice coming from the pink and black. (no longer as in playing around and trying to jump juice without the switch I blew a fuse somewhere). All the wiring diagrams I have found show only an orange wire. Has anyone seen one with a light blue??
If I know which wire to put juice to I can get defroster to work with a jumper wire till spring..
The car is an 83 TA 5.0 eng. (Bought the car new so I know the wire has not been just switched out for another color).
Any help is appreciated. Frosted over windows are a daily thing up here in Alaska!!
Old Nov 2, 2006 | 01:35 AM
Jza's Avatar
Jza
Also check the connectors attached to the hatch dampers. I've had one work loose before.
Jorlain
Aug 24, 2022 05:11 PM
customblackbird
Aug 15, 2021 10:16 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
AkDrifted
Aug 17, 2015 07:45 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
