voltage drop
Old Sep 15, 2006 | 05:47 PM
TigerZ's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
voltage drop
randomly my car's voltage will drop 3-4 volts while driving and some electronics go weird. [lights go dimmer, fuel pump not getting enough juice, misfire, etc.]ive replaced both the alternator and battery.
ideas?
Old Sep 15, 2006 | 06:38 PM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
The 3600W sound system? It pulls more than twice as much as the starter...
Seriously, look for bad connections in the main wiring from bat/starter to key.
Old Sep 15, 2006 | 07:15 PM
TigerZ's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
already did, checked grounds, fuseable links. monitored the alternator and battery during idle, and they're all fine. i jiggled all the grounds around while idling and they're all on tight
Old Sep 19, 2006 | 03:53 PM
Morit's Avatar
Car: Firebird 88
Engine: 406
Transmission: th400
Axle/Gears: 3.50
Do you have stock alternator? Maybe you should change to a bit bigger?
Old Sep 20, 2006 | 09:38 PM
TigerZ's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
im replacing the alternator with a 140amp next week and im gonna install a out of tank fuel pump. hopefully that will fix it
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
