would a bad hazard light switch cause this problem
Old Sep 17, 2006 | 04:20 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
would a bad hazard light switch cause the right turn signals not to work. i know the problem is somewhere in the steering colum. any easy fixs
Old Sep 17, 2006 | 04:31 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Hve you checked the bulb and or the turn signal relay?
Old Sep 17, 2006 | 04:34 PM
jayk2k3's Avatar
Car: 85 camaro z28
yup. this wat happens, when u put the steering colom all the way up and play with the hazad switch the right turn signal will start working
Old Sep 17, 2006 | 04:41 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
That's a tuffy, I have never taken a column apart (and I hope I never have to) sounds like either a bad switch or a short, good luck.
Old Sep 17, 2006 | 04:47 PM
Z28guy83's Avatar
Car: 83 Z28
Engine: 400sb
it could be a bad turn signal switch had it happen to me when i had tilt not too hard to replace
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
TheJoeY88
Dec 31, 2016 07:30 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Omega
Aug 10, 2015 12:46 PM
