Wiper moter question.
Old Sep 23, 2006 | 10:16 AM
BigBoi4Lyph's Avatar
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 9 bolt Borg Warner Disk Brake Posi
so i have no wiper motor in my car and there is a connector with 4 female inserts so i tryed to test it with the wipers on inside but the test light showed now power comming to it at allwho could it be if its not a fuse? thanks
Old Sep 23, 2006 | 03:07 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
The white wire should have 12V on it if the fuse is good.
I assume you don't have the delay function on your wipers?
The other three wires (purple, grey, pink) supply ground signal from the switch in the cab.
I have only a paper schematic here but you can try PM-ing Trickster, he might have one in digital form.
Hope this helps.
Lou
Old Sep 23, 2006 | 08:46 PM
Car: 89 Iroc
Engine: 5.7 TPI
thanks for the reply the white wire has no 12 it has 0 and i do have delay or atleast both steering columns that have been in it as far as i know have had delay on them but its a L shape with 4 inserts none of them get any power and my fuse is good.
Old Sep 23, 2006 | 11:02 PM
BigBadLou's Avatar
Engine: TPI
If the fuse is good and the white wire has no 12V on it, then the problem is between the fusebox and the connector for the wiper motor. THe white wire goes through the C100 bulkhead connector. Try tracing it from the fusebox all the way along and see where it loses power.
Lou
Old Sep 24, 2006 | 02:14 AM
Car: 89 Iroc
Engine: 5.7 TPI
sounds good i did just relize there is no wire its like a light pink or light lan wire its almost white but tis not there is no white wire. so im not surenone of them get and wolts possitive or negative. humm
Hal87
Exterior Parts Wanted
Nov 8, 2015 03:40 PM
Hal87
Sep 26, 2015 09:26 PM
adelane
Sep 9, 2015 08:51 PM
Ian Irvine
Sep 4, 2015 08:08 AM
