Horn not working - previous owner issue
Old Oct 3, 2006 | 05:17 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I bought a very nice '91 Firebird a couple months ago and I'm trying to fix a few of the little issues that is has. One problem I can't figure out is why the horn isn't working. According to the lady that I bought it from (a lady I work with), her husband took the steering wheel/airbag assembly apart for a reason that she doesn't know and when he put it all back together, the horn no longer worked. I'm really confused by this. What could he have possibly done or messed up when he took everything apart that would keep it from working? The horns just look like buttons so it's not like the older steering wheels where if you don't get the contacts lined up right it won't work.
Any ideas would be appreciated.
Old Oct 3, 2006 | 06:58 PM
Chopper_86's Avatar
Car: '82 Trans Am; '85 Camaro
Engine: 350 cid; 2.5 mini 6
Transmission: TH 350
Axle/Gears: Posi Richmond 3.73
Is the airbag or SRS light on? If so, he may have screwed up the clock spring some how
Old Oct 3, 2006 | 08:15 PM
Nope, security light flashes the appropriate number of times to show it's working and then shuts off. None of the lights are on during normal use.
Old Oct 4, 2006 | 11:50 AM
91DropTopTA's Avatar
Car: 91 Trans Am Convertible
Engine: 300 HP 350 CI
Axle/Gears: Drums?
I don't know if you've checked this, but I've had problems with the little plastic contact switches that are behind the buttons on the airbag cover. I took my airbag out to fix some other problems and the switches were cracked and falling apart.
eightsixseven
Dec 16, 2024 01:50 PM
NinjaNife
Aug 23, 2015 11:49 AM
LittleFranks
Aug 20, 2015 03:55 PM
ZsTransAm
Aug 11, 2015 07:30 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
