Radio Shuts Off When I Press Brake Pedal
Old Oct 4, 2006 | 07:44 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
OK, this just started happening today, whenever I press down on my brake pedal, my radio just shuts off then comes back on.
Is it a short somewhere?
Is there a wire getting pinched?
Whats causing my radio to shutoff and come back on?
Old Oct 4, 2006 | 09:22 PM
wiseman9986's Avatar
Car: 82 z28
Transmission: TH350
Axle/Gears: 10 bolt 3.73
it might be finding a ground through it then losing it when you push on it
Old Oct 4, 2006 | 10:26 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Stock or aftermarket radio ?
The radio and ctsy fuse are both completly independant circuits from the 'stop haz' fuse.
Radio circuit is switched via the ign switch and the ctsy is constant power.
Stop Haz fuse is an isolated circuit from either of the above.
Old Oct 4, 2006 | 11:08 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Aftermarket Kenwood Radio.
Also, I did pop the "Tail" fuse today, (think that was it) when I was trying to replace the remote dimmer module, and I replaced it. Could I have possibly popped another one?
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
