guages freeze?
Old Oct 4, 2006 | 09:38 PM
camarodrew's Avatar
Car: 91 rs
Axle/Gears: 4.10
guages freeze?
alright quick question when i shut my car off the guages just sit at the exact spot they were at they work fine and if i turnit back on and shut it off they go back to normal any ideas?
Old Oct 6, 2006 | 11:08 AM
johnblaze322's Avatar
Car: 92 camaro
Engine: V6
i have the same problem did you remove your guages too because thats what i did right before it started to do that
Old Oct 6, 2006 | 09:36 PM
camarodrew's Avatar
Car: 91 rs
Axle/Gears: 4.10
it was doing it when i got it but yes i have took the guages out to fix the tach
Old Oct 6, 2006 | 09:57 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
I'm pretty sure that the guages freezing when the car turns off is normal for these quages. if you had mechanical quages, oil guage for instance I'm sure it would return to zero when the engine shuts off.
Old Oct 7, 2006 | 03:32 PM
camarodrew's Avatar
Car: 91 rs
Axle/Gears: 4.10
i have all electronic guages its just anoying to see them stay like that is there any way to fix that
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
sheachopper
Jul 31, 2019 11:27 AM
