hesitation and coil arcing to coil wire post.
Old Oct 9, 2006 | 11:47 PM
Camas_Camaros's Avatar
Car: 1988 Camaro RS/1983 camaro z28
Engine: V8 305 L69
Axle/Gears: 2.73 posi
so i replaced my spark plug wires and now i get hesitation when i press the gas pedal in the 750-2000rpm range but after that its fine. my coil is also arching so im thinking its the coil but i just want to sure. and if it is the coil im switchnig to carb soon and i was wondering if i can run my tbi setup with an hei distributor instead of the stock type one (i know that is a question for a different forum though). all help is apreciated. thanks
Old Oct 10, 2006 | 05:26 PM
Engine: V8 305 L69
any help is good for me, i really need this fixed.
Old Oct 10, 2006 | 09:02 PM
phtech's Avatar
Car: 1987 Formula/ 1990 Firebird
Engine: 5.0 Vin F/ 3.1 Vin T
Transmission: 700R4 in both
Axle/Gears: Haven't checked
where is it arching from? what type and size wires did you use?
Old Oct 11, 2006 | 01:15 AM
Engine: V8 305 L69
its archong from the very center of the coil to the bottom of the coil wire boot (on the coil it self not the on the distributor) i replaced the wires with the stock replacement size because i was getting detanation when i put a load on the engine but it was fine with out a load on the engine.
Old Oct 12, 2006 | 05:57 PM
phtech's Avatar
If the coil housing isn't cracked, I would start by checking the grounds on the engine. there is one on the back of each head, and one or two on the front bottom corners.
Old Oct 13, 2006 | 03:04 PM
Engine: V8 305 L69
well i found the problem, the next time i change my spark plug wires im going to put it on jack stands so i can do all of them my self so i dont have to have some one else do the back ones, my #7 cylinder spark plug wire was not connected and electrical current always takes the path or least resistance doesnt it? works great now. thanks for your guys help, i do feel really stupid now though.
Ikes 91Z
Dec 9, 2015 03:49 PM
stalkier
Dec 6, 2015 11:25 PM
db057
Aug 22, 2015 08:17 PM
Dialed_In
Aug 20, 2015 01:45 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
