PLEASE HELP DIGITAL DASHCONVERSION
Old Oct 14, 2006 | 07:50 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
I AM TRYING TO ELIMINATE THE DIGITAL DASH IN MY 89 GTA.I HAVE ALREADY REMOVED THE DASH AND INSTALLED A DASH FROM AN 88 FIREBIRD.I DECIDED TO JUST CHANGE THE CLUSTER CONNECTORS INSTEAD OF THE COMPLETE INTERIOR HARNESS.THE PROBLEM THAT I AM HAVING IS THE VOLTAGE AND FUEL GAUGES ONLY WORK CORRECTLY IF I SWITCH THE DOME LIGHT ON VIA THE DIMMER SWITCH ON THE TOP PART OF THE HEADLIGHT SWITCH, THEN BOTH GAUGES WORK FINE UNTIL I CLOSE THE DRIVERS DOOR.OF COURSE THIS ALL TAKES PLACE WITH IGN. ON . ITHINK IMAY HAVE A GROUND ON THE WRONG CIRCUIT.IS THAT POSSIBLE?I KNOW SOME STUFF ABOUT WIRING, BUT DO THE INTERIOR LIGHTS AND ENGINE GAUGES USE DIFFERENT GROUND SOURCES?
Old Oct 15, 2006 | 05:45 PM
I FOUND MY PROBLEM TODAY. I HAD NO GROUND ON HEADLIGHT SWITCH OR THE FUEL&VOLTAGE GAUGES.INSTEAD THE GROUND WIRES WERE ALL CONNECTED TOGETHER INSTEAD OF TO GROUND.(HOW I MANAGED TO DO THAT,I'LL NEVER KNOW),BUT EVERYONE THAT IS FAMILIAR WITH CARLOS MENCIA I THINK WILL AGREE, THAT DESERVES A DEE TA DEE AWARD
InfernalVortex
Apr 20, 2021 11:31 AM
sheachopper
Jul 31, 2019 11:27 AM
Lbibb
May 5, 2016 12:00 AM
rusty vango
Sep 29, 2015 02:44 PM
Eric-86sc
Sep 28, 2015 11:37 AM
