More blower motor issues...
Car: 1983 Camaro Z28/1999 Cavalier
I was looking at my blower motor for my heater/AC today, to see if I could get it working.. oh boy this is fun.
I started by replacting the relay thats under the hood, nothing. So, I bought a new switch, hooked that up and nothing.
So, out came the test lights and wires.
First, I wired the blower motor directly to the battery and it works. Ok...
So, I tested for power after the relay, no power.. I tested for ground, no ground either.
I tested for power before the relay, it has power. But, there is no ground. There are supposed to be 5 prongs?? on the relay, and obviously 5 holes?? for those prongs to go in.. one of those holes has no wire in it, so I am thinking there is suppsosed to be a ground there..
So, I directly grounded the blower motor and tried to work it with the relay plugged in, nothing.. I am assuming I had nothing because there is no ground for the relay.
Does any of this sound right? I can take a picture of the relay and stuff if need be to help understand better..
I have it hard wired right now, directly to the battery with a switch on the + wire.. because I need something pretty bad..
Suggestions?
Suggestions?
Car: 1986 camaro z28
Engine: 350sbc
Transmission: TKO 600
Axle/Gears: stock axle with 4.11's
Re: More blower motor issues...
maybe your relay is bad...rare for the relay to burn out but from what youve said here sounds like your problem...
Street Lethal
Aug 13, 2015 08:28 PM
