305 to 350 swap
Old Nov 3, 2006 | 12:01 AM
toms86Z28's Avatar
305 to 350 swap
ok i just got a 350 from my friend for $275. the motor was rebuild about 5,000 miles ago. im going to swap out the cam for a comp cam exteam fuel injuction cam. with a set of alum. heads mybe from edlbrock or trick flow. one question would be the stock comp. ratio on a 350. and what size is the combustion chamber? i want to be around 9.5:1 or 9.8:1. and the last question is im my 86 camaro z28. is the 305 tpi do i need to get a new computer to use the 350 or can i just change the chip in it. and when i figure that out im gunna order a custom chip from PCMforless.com
thanks for the help. and what size injuctors should be used
Jake_92RS
Jan 28, 2020 10:37 PM
bellez77
Sep 5, 2015 08:39 PM
st.evel07
Aug 13, 2015 06:15 PM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
