Need Help starting car
Old Nov 7, 2006 | 06:37 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
Hey guys I need some help..... I tried searching and tried a few things that I found. But it still won't turn over! It will turn over if I put power to the starter...
The car is a 92' Camaro Z28, I took out the computer and installed a Holley 950 Commander computer and wiring harness. I also got rid of the 700r4 and installed a TH350.
Will the VATS not work with the computer removed?
So far I connected the Large Green and the large Yellow together, nothing!
When I turn the key to start the Large yellow has 12v.
Ray
Old Nov 7, 2006 | 07:05 PM
86camedcamaro's Avatar
Transmission: 350 turbo
neutral shafty switch under the dash i had the same problem.
Old Nov 7, 2006 | 08:39 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
If I run a jumper wire from the large purple to the large Green, will that work? I refering to the plug at the shifter.....
Ray
Old Nov 7, 2006 | 09:38 PM
I'm not very sure but i did like a race car setup push butten start so i couldn't tell ya but you could try it
Old Nov 8, 2006 | 10:08 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
Ok, I put a jumper wire on the large purple and large green (neutral switch plug) nothing. When I turn the key, I get power at the large purple.... I'm stuck! It must have to do something with the wiring harness and computer I removed.
Ray
Old May 4, 2007 | 07:56 PM
quix99's Avatar
Car: 1989 gta
Engine: 350 mini ram, zz9
Re: Need Help starting car
i was wondering if anyone had a solution to this problem because i am stuck with it also, i have good voltage everywhere in the car, but the starter wont even crank. any takers?
Old May 4, 2007 | 09:31 PM
rtkjadams's Avatar
Car: 92 Camaro Z28
"QUIX99" I figured out what my problem was..... I had the small wire that does to the starter on the wrong termanal of the starter... Ooopps
Ray
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
L98GTA87
Aug 5, 2015 11:02 PM
