Need pic of Heater Blower relay and connector
Old Nov 7, 2006 | 11:06 PM
cdoyle's Avatar
Hi,
Can anyone take a pic of the heater blower relay and the connector it plugs into?
As you know I'm trying to install that newer style heater box into my 84, and I've been reading that the A/C models have the relay. Trying to figure out what connector the relay goes on. I have 3 connectors on the harness, but none of them really look like one for a relay.
Is it a special type relay?
Chris.
Old Nov 8, 2006 | 05:39 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Look in the following link:
https://www.thirdgen.org/forums/cool...er-heater.html
JamesC
Old Nov 8, 2006 | 08:31 AM
cdoyle's Avatar
Thanks,
I've seen this pic, but I was hoping for a closer up pic of the connector for the relay.
Is the connector part of the wiring that goes through the firewall to the switch?
Old Nov 8, 2006 | 09:47 AM
JamesC's Avatar
Wiring from an 86:
http://www.geocities.com/vtcamaro/Pi...rams/pg238.jpg
JamesC
Old Nov 8, 2006 | 05:23 PM
cdoyle's Avatar
Ya I have the wiring diagram, but I have 3 connectors under the hood that aren't used. I think 1 of them are for the relay, the one I thought was for the relay is an oval shape. The other 2 are found.
I thought maybe the oval shape one was it, but then looking at the pic in the first link. It looks like a normal square relay is used. So now I'm not sure.
That's why I would like a closer up pic of the relay connector. To help me locate it.
Old Nov 9, 2006 | 06:41 AM
cdoyle's Avatar
Nobody has a pic?
Have another question, I have the blower motor in. The lower speeds work, but I've noticed that when I turn the fan switch to 'off' the motor still spins slowly.
Is that normal?
I can't remember if it did that before or not?
Chris.
Old Nov 9, 2006 | 10:51 AM
JamesC's Avatar
The plug is squarish. Check the above link for colors (maybe black, red, orange, and purple or brown--I don't recall offhand).
JamesC
Old Nov 9, 2006 | 04:41 PM
cdoyle's Avatar
It's not this one is it?
It's the only one that has all those wires?
I don't see any cut wires anywhere so not sure??
Old Nov 9, 2006 | 05:37 PM
cdoyle's Avatar
Oh does anyone know the answer to the fan on/off thing I have going on?
Old Nov 10, 2006 | 07:34 AM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
On my '84 there is always a low air flow out of the vents even with the switch off. I'm pretty sure the air is from the blower spinning at low speed. Normal for GM cars.
Old Nov 10, 2006 | 07:45 AM
cdoyle's Avatar
OK that's good to hear.
When it didn't shut off, I thought I had wired something wrong, but there really isn't much to wire wrong. So I was starting to think it was suppose to do that.
Does that pic I took of that connector, does that look like the one that the relay is suppose to go to?
Old Nov 10, 2006 | 08:01 AM
8492bird's Avatar
Engine: 2.8/3.1
Transmission: auto
It might be if it's got 4 or 5 wires to it. My car had an aftermarket A/C put in by the dealer, and the relay and wiring are not stock so I can't help there. Here's a wiring diagram for an '84
84(2).pdf
Try the partsamerica.com web site - they have pretty good pictures of the relay that might give you an idea if that's the plug or not.
Old Nov 10, 2006 | 09:37 AM
cdoyle's Avatar
thanks,
I think I may have to go the junk yard and see if I can find it.
The partsamerica website doesn't hve a pic of the relay. bummer was hoping they would.
Old Nov 10, 2006 | 10:17 AM
8492bird's Avatar
Engine: 2.8/3.1
Transmission: auto
Try these links
1984 relays
http://www.partsamerica.com/ProductL...ioning%20Relay
1992 relays
http://www.partsamerica.com/ProductL...Blower%20Relay
Old Nov 10, 2006 | 10:33 AM
cdoyle's Avatar
Cool Thanks,
I must have not been using the right keywords.
But looking at those pics, it does look like that is the right connector I have. Just need to get the relay
Thanks!!
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
89GTAOz
May 16, 2020 09:31 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
soarestransam
Sep 1, 2015 04:00 PM
