cold heat
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
i dunno if it's just that i don't know how to use it or what, but stick with a conventional soldering iron, battery powered is no good and when i tried it i couldn't even get the thing to solder anything, and it's bulkier and awkward compared to a regular soldering iron.
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
It's good for soldering some basic electronics but dont let it anywhere near your car. Not hot enough to do a decent job soldering anything near as complicated as your ecu.
Car: Red 1984 Z-28
Engine: 4.8 LS
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
In case anyone is interested...
The "cold-heat" process works in a very simple manner. The tip is actually divided into two contacts, split down the middle. One side is positive while the other is neg. When the solder contacts the tips, it closes the circuit and allows the electricity to convert into heat.
It just sounds inefficient and wasteful to me, but that's just my opinion.
I've not personally used one, but at the rate I go through tips on my regular iron, tinning and all, I think those things would be money pits. Those 2-contact tips can't be cheap.
