What do I do?
Old Nov 17, 2006 | 11:50 AM
rjpbboi's Avatar
Car: 87 Trans Am, 89 RX7
Engine: 350tpi,350carb
Transmission: T-5,t56
Axle/Gears: 3.42 Posi,4.11 posi
What do I do?
OK, awkward question. I was removing my starter motor today and was taking out those large bolts that connect it to the flywheel, and the top of the bolt broke off, so the rest of the bolt is stuck in place, but the starter motor and everything is off. Is there a tool that will extract the rest of the bolt?
Old Nov 17, 2006 | 11:58 AM
crowebuilt's Avatar
how much is sticking out? any
Old Nov 17, 2006 | 12:12 PM
rjpbboi's Avatar
maybe an inch
Old Nov 17, 2006 | 12:18 PM
crowebuilt's Avatar
try a good set of vice grips aftre you spray the one inch ray of hope with PB BLASTER. let tha peatrant sit for about 20 to 30 minutes. that should do it. let me know.
Old Nov 17, 2006 | 01:30 PM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
If your still stuck after , then try to file a flat or two on the end of your exposed stud. That'll allow some better grip for the vise-grips.
You're quite lucky, every time I snap a bolt, it's always buried in the damn hole. Good luck.
Old Nov 17, 2006 | 01:50 PM
rjpbboi's Avatar
What do you do when this happens?
Old Nov 17, 2006 | 04:41 PM
crowebuilt's Avatar
two things come to mind real quick. 1st, i would use eay out. you drill a small hole in the broken bolt then, tap the easy out in the hole and start backing it out. it has flutes like a reverse drill bit. if that fail drill and tap time. dont drill out the remaing good threads, start small and work your way up. sometimes the bolt will come out before the tap is needed. this usually happens when the bit "grabs" more than the drill can turn.
Old Nov 17, 2006 | 05:59 PM
Jza's Avatar
Jza
Only thing is, every time I've used an easy out, IT gets snapped off in the hole, and you can't drill an easy out... out..
Old Nov 17, 2006 | 07:04 PM
rjpbboi's Avatar
I went to do this only to find that the thread of the bolt wasn't sticking out enough for me to do this. Thanks for the reply though.
