TAIL fuse driving me crazy ! Turning on the headlights pops fuse right away...
Old Nov 18, 2006 | 03:11 PM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
So i know i have either a bad bulb, or a ground somewhere blowing my TAIL fuse. After reading around seemed like the best way to chase down a bulb was to pull em all out and check from there one by one. I went ahead and replaced the headlight switch, and So far ive removed:
all the tail light bulbs
all the speedo bulbs
the turn sigals up front
The side markers
The console and hvac bulbs (did the radio have a bulb?)
There was no bulb in the underhood light
Pulled the little ashtray light also
And still it pops right when i pull on the headlight switch. Am i missing some bulbs somewhere ?
I do have an aftermarket radio, but it's wired correctly.
Old Nov 18, 2006 | 04:25 PM
paulmoore's Avatar
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
I'm thinking that you have a short to ground somewhere on the power side of the headlight circuit. I would visually check the wiring that is at the back of the headlights, and follow them as they go back into the car and make sure that none of the wires got pinched or anything.
Old Nov 19, 2006 | 11:20 AM
91Z28's Avatar
Car: 91' Z28
It must be a short somewhere because i pulled everything and still popped a fuse, man electrical problems are frusterating, whats the best way to track down this thing after the bulb test ? Trickster ?
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
