Oil Pressure Idiot Light problem
Old Nov 29, 2006 | 07:29 PM
BerlinettaNick's Avatar
Car: 1984 Berlinetta
Engine: 305 H
Transmission: Original
Axle/Gears: Original
84 Berlinetta factory stock: I don't know if this is an electrical or mechanical problem, but the oil pressure idiot light comes on when I am driving, particularly at high speeds above mach 2, or when I accelerate with afterburners from 50 mph. Oil level is full. Oil pressure gauge says plenty of oil pressure. Sometimes the idiot light will stay on for a long time or until I slow down under mach 1. Do I replace the oil pressure sending unit behind the distributor? Is there another sensor somewhere that I need to replace? I've driven far enough with the light on that if there was really low oil pressure it would have siezed up the engine. I just don't feel comfortable with that idiot light coming on time after time and the light dispaly on the dash resetting to OK when I slow down. Any suggestions? Thanks!!
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
