everything weak, (lights,windows,hatch etc)
Old Dec 6, 2006 | 05:21 PM
Pennocks91ws6's Avatar
Car: 91 formula ws6
Engine: 1 peice roller scat 383 4 BOLT!!
Transmission: 5 speed
i just bought the car so i dont know to much about it, but i know the alternator is newer, and the battery is new but from canadian tire(will change soon) but eveything is slow, power antena stugles to live hatch takes 10 second to release, power locks even suck, is this some kind of drain? or is it a simple wire?
Old Dec 7, 2006 | 06:01 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Go simple first. Clean and lube the antenna with WD-40 or some other light lube. I have no experience with the power pull down, but it's conceivable, I guess, that it too might improve with cleaning and lubing. Power locks and slow windows are often caused by gumming (a common thirdgen problem). Again clean and lube. Should you go inside the door to accomplish this latter, the following link may be helpful:
https://www.thirdgen.org/forums/body...servation.html
JamesC
Old Dec 7, 2006 | 07:36 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
That's excellent advise to follow from JamesC.Clean and lube everything,do an oil change/lube underneath if you haven't already(not a bad idea to flush/fill the cooling system).If the your T/A had been sitting for a long period of time before you bought her the battery may have discharged(especially in cold weather).If you have a battery charger,or access to one,fully charge the battery.An alternator is meant to maintain the charge on a battery not fully charge a dead one.Check all electrical connection for corrosion and condition of the cables.
Old Dec 7, 2006 | 07:41 AM
TexasSilhouette's Avatar
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
Check the voltage at the fuse block while running a window down. See if you have battery voltage.
Old Dec 8, 2006 | 03:39 PM
Car: 91 formula ws6
tahnks all, dirt outer window seals were the culprit for the windows going slow, but theres definetly a lack of power and im surw battery and altenator is fine, ill test the volts going into them on the weekend
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
stalkier
Aug 21, 2015 01:54 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
