new distrbutor not lining up
Old Jan 13, 2007 | 12:37 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i bought a new distributor for my 89 350 camaro today ,i marked the old one to spots on the firewall and motor.however ,when i got it home it doesn't line up to my marks.! so now what should i do? it's about a eighth to a quarter inch off. it's the shaft that isn't lining up.
Old Jan 14, 2007 | 07:12 AM
JohnZ28's Avatar
Car: 85 Z28
Engine: 383
Transmission: TH350
Axle/Gears: 3:73
You might want to try turning the rotor button counter clockwise a little before you drop it in the hole.
As the dist. gear meshes with the cam gear it will turn the dist. shaft and cause it to turn clockwise and throwing your alignment off.
You might also have to turn the oil pump shaft slightly for everything to line up again. I use a big screw driver and a good light.
Have fun
Old Jan 14, 2007 | 09:28 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
good idea i will try it tomorrow ,and post .
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
romcjr
Sep 17, 2015 05:18 PM
TBRays98
Sep 6, 2015 05:05 PM
