Not another power seat question!
Old Jan 30, 2007 | 07:59 PM
TreyR's Avatar
Ok I searched And searched, and I could not find what I needed. I just got in my leather seats in from a 02 Trans Am My problem is My search only pulled up 2 wire seats I have 6 wires and do not have the wiring harness. What are they for, Which is the hot and the ground. Which go from the drivers side to the passenger side to operate the compressor pump?
Also my passenger seat has the pump for the power bolsters it has 2 hoses hanging from it and so does my drivers seat my guess is I need to run vacuum lines from the passenger side to the drivers side. Am I right?
Thanks in advance
Trey
Old Jan 31, 2007 | 05:45 AM
TreyR's Avatar
Any help or links would be greatly appreciated!
Old Jan 31, 2007 | 06:27 PM
TreyR's Avatar
Is this one too hard for ya?
Old Jan 31, 2007 | 06:48 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
I have 02 TransAm seats in my IROC but it came with a harness. You need power for main seat controls and you need power for the lumbar control and the Bosters. you also need to send power under the center console to passenger seat it has lumbar and Bosters also.
At least mine did. Without having a Harness you could try jumping 12Volts and ground to the wires you have and see what works and what dosen't.
jaridjohn
Jul 8, 2024 03:49 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
