5" tach in cluster?
Old Feb 2, 2007 | 10:26 PM
1987camarosport's Avatar
Car: Camaro
Engine: worked 350
Transmission: automatic
Axle/Gears: 3:73
5" tach in cluster?
Hey all
I have a question, How hard will it be to hook up my 5" tach into the stock camaros tach location. I dont care if i loose the oil pressure guage due it not working. The tach fits purfectly snug w/ the bracket in the opening but how do i get it to fit in do i need to cut the stock guage cluster? if so will that ruin anything else? any help is geat id love to do this tomorrow.
PS the tach is all wired already just want it in a new location. and under the vents i have 3 guages already.
Old Feb 3, 2007 | 05:38 AM
JohnZ28's Avatar
Car: 85 Z28
Engine: 383
Transmission: TH350
Axle/Gears: 3:73
I put a speedo and tach in mine last winter. You will have to cut and grind to make it fit. Took a bit of time and had to remove the cluster from the car.
I enlarged the holes in the outer trim piece and made them a tight enough fit to hold the gauges in place. There are no brackets behind the gauges securing them. Worked perfect.
Old Feb 3, 2007 | 09:48 AM
Car: Camaro
Engine: worked 350
Axle/Gears: 3:73
how hard was it to modift the stock guage cluster? what needed to be removed obvously the stock tach..
Old Feb 3, 2007 | 10:00 AM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
[QUOTE=1987camarosport;3212493]....I dont care if i loose the oil pressure guage due it not working.....QUOTE]
Old Feb 3, 2007 | 11:24 AM
Car: Camaro
Engine: worked 350
Axle/Gears: 3:73
[QUOTE=freestylzz;3212816]
yeah becuase i have another oil pressure gauge with 3 other gauges in a pod...
Old Feb 3, 2007 | 02:07 PM
Car: Camaro
Engine: worked 350
Axle/Gears: 3:73
heres how i did it today just mounted it in front of the old tach
what do ya think its simple and looks good,.
Old Feb 3, 2007 | 08:50 PM
JohnZ28's Avatar
Car: 85 Z28
Engine: 383
Transmission: TH350
Axle/Gears: 3:73
The hole in the black trim piece had to be enlarged just enough to hold the gauge tightly.
The clear plastic piece on the cluster has to be modified and then there is a black metal piece under that that has to be cut as well and the old tach and mounting points are removed. You just have to cut and grind till there is enough room. Everything in the dash still works, minus oil pressure.
It took most of the day cutting and fitting and wiring everything so it looked and functioned right.
If I was just mounting a tach only I think I would have done it differently. Like 1987camarosport did.
$750 L98
Feb 1, 2025 02:25 PM
Eric-86sc
Sep 28, 2015 11:37 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
TrevinE
Sep 14, 2015 03:20 PM
