cts or tps help
Old Feb 9, 2007 | 01:18 AM
z28camaro091's Avatar
cts or tps help
ok i have a 91 z28 with a 335 stroker motor and i just bought it a week ago and it won't start easliy and it is blowing black smoke out the tail pipes so it is overloading when it starts it shakes and sounds like **** when i shut it off a lst it sit no more than 10 secs it will not restart so i was wondering could this be the cts or tps i also already changed the o2 senser and the map senser so it wasn't that plz give me some info with what u guys think is mire likly the problem.
Old Feb 9, 2007 | 02:53 AM
ZimGTA's Avatar
Car: 88 GTA
Engine: 383
Transmission: 700 r
You should check your fuel pressure regulator. Pull the vacuum line off, if there is fuel in it, the diaphragm has a leak in it.
92camaro350cci
Oct 14, 2015 09:29 AM
Fred SS
Oct 12, 2015 11:27 AM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
