lets see your remote disconnect switches
Old Feb 11, 2007 | 09:13 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
got the battery in the trunk and need a disconnect switch for the track this year.
Dont care if its on a camaro or some other car, want to get some ideas for how i can put it on my car and it not look awful
Old Feb 12, 2007 | 12:46 AM
AmorgetRS's Avatar
Moved to Electronics, better chance here.
Old Jun 4, 2007 | 08:38 AM
bluegoose's Avatar
Car: Firebird
Engine: 383
Transmission: 700R4, lots of Mods
Re: lets see your remote disconnect switches
hey all, I have a 89 bird and relocated the battery in the rear, I also would like to see pics of your battery disconnect switches..need this switch installed before I can race...
What are the rules on where to mount this switch??
Brad
Old Jun 4, 2007 | 10:38 AM
BA92GTA's Avatar
“If the battery is in the stock location, the stock hold-down mechanism is OK. But if the battery has been moved, it must be securely mounted to the frame or the frame structure with at least two 3/8-inch bolts and metal straps. J-bolts are not legal. The rules also require any trunk-mounted battery to have an external battery-cutoff switch and be vented outside the trunk. Also, if a trunk-mounted battery is not enclosed in a box, a firewall must be fashioned between the trunk and the driver using .024-inch steel or .032-inch aluminum plate.</SPAN>”
www.hotrod.com/techarticles/nhra_track_inspection_checklist/index.html
In addition to this, there are further requirements for the battery the faster you go.
I have added a tech article from HOT ROD.
Oh, I have a 92 GTA, and installed mine of the top of the bumper.
Old Jun 4, 2007 | 05:49 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
Damn, so many rules, maybe I'll just put the damn battery back to its stock location!!!
If my batter is in the back, and I have like a plastic boat battery holder in which the battery is in, how do I vent this, when the top isnt air tight??
Where should the cuttoff switch be located??
Old Jun 6, 2007 | 09:07 AM
bluegoose's Avatar
Car: Firebird
Engine: 383
Somebody must have a disconnect switch installed on their 3rd gen, plz post the pics, I need some ideas..I really dont want to drill any holes....
Brad
Old Jun 6, 2007 | 02:38 PM
z28camaroracer's Avatar
Car: 84 Z28, 89 RS, 98 SS
Engine: 350 .060 over, 350 .040 over, LS1
Transmission: TH350, TH700r4, T56
Axle/Gears: 4.11 spool, 3.73 open, 3.42 posi
Here is a pick of my cut off switch, I used the summit racing sealed battery relocation kit and taylor cut off switch.
I will have to find the pics tonight and post them. I removed the license plate and cut the strip between the mounts and installed the switch there with the plate reinstalled you can't tell it is there. when i go to the track i remove the license plate.
Old Jun 6, 2007 | 03:05 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
Cant wait to see the pics, been told about removeing the plate and intalling the switch...I bet I am going to like your setup!!!
Brad
Old Jun 6, 2007 | 08:39 PM
Here are the pics of my install.
Old Jun 7, 2007 | 06:29 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
thats awesome and definitly looks like the way too go, its too bad with these cars the battery box is too big to fit in the wheel well and you lose your whole trunk.
Old Jun 7, 2007 | 07:25 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
Yes sir that looks good, you gave me a lots of ideas, going to order some parts tonite
Old Jun 7, 2007 | 07:35 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
z28camaroracer:
Do you remember the part number of the switch??
Is that an electric cutoff switch?? if not what are those other pos and neg (smaller gague) used for...
Old Jun 7, 2007 | 07:44 PM
iamtheantirice's Avatar
i had a neighbor with a drag truck. he got a custom liscense plate that said "ON OFF" and drilled a hole in the center of it. mounted the switch there. i thought it was pretty sweet. dunno if it was legal though =)
-chris
Old Jun 7, 2007 | 07:50 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
cheating is leagal until you get caught!!!
Old Jun 7, 2007 | 11:31 PM
The number is tay-1033 on summitracing.com. The small gauge wire is for the alternator shut off it connects power to the red wire at the alternator. Just remember when you finish your install that you test to be sure that the engine shuts off when you turn the switch off. If it does not you will have to rewire it so it does.
At our local track there is a guy with a second gen that has the cut off switch in the middle of his license plate.
Old Jun 8, 2007 | 01:10 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
z28camaroracer:
Hey never ever thought about the alternator, there must be a may I can disconnect the power source to the alt when I disconnect the battery without having to run another wire to alt.??
Also in your last pic it apperars that you have some type or foil tape or something wraped around the positve cable...can you tell what that stuff is adn why you have it.
Brad
Old Jun 8, 2007 | 03:59 PM
The foil is actually asbestos heat wrap, I did not want to have to worry about it getting hot and damaging the cable.
You have to run the second wire, because every thing after the dia connect switch will stay powered up if the switch is turned off because the alternator is still charging because the red wire is hooked up to a constant 12v sorce the main lead on the back.
Old Sep 6, 2007 | 08:28 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Any other pics of battery disconnect switch mounted?
Old Jul 11, 2008 | 05:22 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
Bringing this back from the dead.
Does anybody have any pictures with a Moroso switch mounted to the tail lights? I am in the process of wiring up my optima yellow top and I have a BMR weld in battery box inside the spare tire area. Would like to see how the switch is mounted to the rear light?
gta892000
Aug 11, 2019 11:16 AM
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
Randomtask2
Sep 10, 2015 08:37 AM
luvofjah
Sep 3, 2015 07:08 PM
