MSD ignition 6al question
Old Feb 26, 2007 | 01:57 AM
pmpnavt's Avatar
Engine: L98 350
Transmission: 700r-4
i just installed a msd 6al box into my car. the car runs fine so far, but it sounnds like the Accel dist is making alot of noise after the install. its just a faint high freq sound, almost sounds like you can hear the rotor and cap arc now. anyone heard of this? i pulled the cap off and checked the inside and all is normal. when i listen to the engine up close its coming from the dis for sure. thanks!
Old Feb 26, 2007 | 08:59 AM
pmpnavt's Avatar
Engine: L98 350
ttt
Old Feb 26, 2007 | 08:57 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Thats interesting!
I personally would not put any accell product in my car. I've just had crappy experience with thier plugs, ingition module and wires. I have the Crane Hi6S ignition and BW cap and rotor. No noise whatsoever. I would check your pickup coil and ignition module for noise. If that does not work i'd replace the cap and rotor with something other than accell.!
Old Feb 26, 2007 | 10:48 PM
pmpnavt's Avatar
Engine: L98 350
thanks!
Old Feb 28, 2007 | 01:58 AM
Siggy's Avatar
Car: 1988 Camaro IROC LB9 F
Engine: 305 HO EFI
Transmission: TH700R4
Axle/Gears: GU5 LS 3.23
Your ringing reminds me of a ringing I got when I installed a Crane Hi6 in my 3G...I had the wiring wrong between AB connection at the ignition module ended up with 12vdc on both, engine ran plus ringing. I ended up with a bad ignition module. I replaced module corrected the wire...all is well, no ringing. Not sure if this helps but its worth a thought.
BRoss99
Aug 10, 2025 05:08 PM
9192camaro
16
Feb 3, 2019 12:21 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
tartagliaz28
Aug 15, 2015 10:59 AM
