Im tired of these gauges threads
Old Feb 28, 2007 | 01:48 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
So i'll start another and ask if anyone has found a viable solution to the "wiring" on the back of our gauge clusters. I specifically am referring to that found on the back of the 140mph gauges from an 87 IROC.
That which I am specifically referring to laughably is the pieces of flat copper laid out over the back of the gauge panel laminated together into some format that is intended to resemble PCB going from one gauge, to an indicator light, to the matching wire on the harness.
Years of stress has turned my "PCB" into junk and finding a replacement does not seem likely. I can't afford new gauges right now, so does anyone have any ideas for a replacement? I am sure I am not the only person to have encountered this problem.
Old Feb 28, 2007 | 03:00 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Covans Classic makes a nice cluster swap package that includes a solution to the wiring connector.
Old Feb 28, 2007 | 05:43 PM
Car: 1987 IROC Z
I drool over the covan's packages daily, but on a limited budget, OMF.. one must fabricate
Old Feb 28, 2007 | 05:55 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you need to repair broken traces on the flexible circuit board, there are electrically conductive epoxies that would probably work.
Old Feb 28, 2007 | 08:01 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
I'd just solder jump wires to the traces if I had to fix that issue.
Old Feb 28, 2007 | 10:07 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I did just that. Just one of the 3 or 4 wires used in various places.
Old Mar 1, 2007 | 01:54 PM
Car: 1987 IROC Z
Did that work well (replacing it with wire) ? I don't want a jitney jungle behind the cluster. What gauge of wire did you use ?
Old Mar 1, 2007 | 08:18 PM
Al Hasse's Avatar
No problems so far. If memory serves, that is 24 AWG wire that is available to me at work. Should be no problems using up to 16 AWG or even 14 AWG. Notice I even took care of a few loose grounds by soldering the lugs to the copper trace.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
g.l.mos
Aug 22, 2015 12:02 AM
