Headlights stuck on Bright
Old Feb 28, 2007 | 02:48 PM
edyer1's Avatar
How do you change out the dimmer switch on a 1991 Pontiac Firebird? The Headlights are stuck on Bright. I thought it was the multi-functional swith but, that is the level. I know the dimmer should be on the steering colum but, how do I get to it to change it? My book does not show me.
Help
Ed
Old Sep 22, 2011 | 11:18 PM
92Firebug's Avatar
Car: 1992 Pontiac Firebird Base
Engine: 305 TBI
Transmission: 700r4, B&M shifter & shift kit inst
Axle/Gears: 3:23....10 bolt
Re: Headlights stuck on Bright
Help
Ed
Bump because I have this problem and I need help to fix it!
Old Sep 23, 2011 | 07:58 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
The switch is easy to change. It's down the steering column under the kick panel. Just pull on the hi beam lever while your head is under there and you see the rod acuating it.
The switch might not even be bad, it may simply need an adjustment. The switch is slotted.
Old Sep 23, 2011 | 04:12 PM
92Firebug's Avatar
Engine: 305 TBI
how do i even find it?
Old Sep 23, 2011 | 04:40 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
It's easier to see if you remove the panels under the steering wheel. The rod runs right up against the column at about 10 o'clock. Pull the lever and you will see the rod move. Follow it down to the switch. You can push in on the switch to change back to low beams until you adjust it. Sometimes tilting the wheel up or down will also make it work temporarily. Two 5/16? or 7mm? bolts need to be loosened just enough to allow you to take up the slack enough to make it work right. Make sure the wheel is tilted to where you normally drive before tightening the bolts back up
Old Sep 23, 2011 | 05:46 PM
92Firebug's Avatar
Engine: 305 TBI
found the lever and flippedd it back to low beam...it works thanks
F-body-fan
Jan 12, 2023 01:49 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
