Elec Fuel pump connector
Old Mar 12, 2007 | 08:02 AM
kaptinkafeen's Avatar
Hey guys,
I am in the process of pulling my gas tank to replace the fuel pump. The connector is kept together using a white plastic 'pin'. I don't know how to get the connector apart without ripping/destroying it. Any hints on how to do this.
TIA
-Andrew
Old Mar 13, 2007 | 09:59 PM
Brads RS's Avatar
its not needed just pull it out and junk it. The connector has a snap coupeler, that white pin is just a safty. With a little care you can take it out without messing it up.
Old Mar 14, 2007 | 07:22 AM
I fiddled with it for a bit, but the thin end of the pin (the part that goes through the actual connector), woudn't squish together enough to pass through. Using a set of needle nose pliers, wasn't helping, so in the end I had to cut the pin to get the connector apart.
Ah well...
-Andrew
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
