HEI and non-HEI spark plug wires
Old Mar 12, 2007 | 09:30 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
i dunno what type of distributor i have but i was told it was a non HEI since i have a small cap. i need to buy spark plug wires for my car(custom kit) because i got headers. but if i dont have an HEI can i use HEI wire kit? what would the difference be? they look right have all the correct boots and everything theyre just a lot thicker. thanks in advance for any help
Old Mar 12, 2007 | 09:36 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
im not sure if HEI large cap wires will fit on the FI small cap towers or not but the only (visual)difference that ive noticed between these two wires is that the HEI large cap ones have the ring on them for the retainer deal that pops on over all the wires
dunno otherwise
diameter of the towers and length of them would make or break this
but then you could just swap boots on the wires,
good luck
Old Mar 12, 2007 | 09:58 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Both the large and small HEI caps use spark plug type terminals. Older points distributors used a socket style terminal.
Old Mar 13, 2007 | 12:31 AM
Engine: LO3
so i can use HEI wires on my non HEI i think it is distributor? BTW its a custom cut to fit kit by MSD.
Old Mar 13, 2007 | 12:40 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Your distributor, if it's stock or a stock replacement, is HEI. To tell, just pull a plug wire off the cap and look. If the terminal on the cap looks like the terminal on a spark plug, you need HEI terminals on your wires.
Old Mar 13, 2007 | 12:02 PM
Engine: LO3
o ok thanks a lot i was being told it was non-HEI. at least i got the right wires for it then by MSD. thanks a lot guys
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Bryan F
Aug 18, 2015 02:28 PM
