Help needed
Old Apr 1, 2007 | 09:19 PM
IROCKERZ's Avatar
Help needed
I'm doing a v6-v8 swap on my RS. How do I bypass the starter without using the neutral safty switch. The wiring diagram shows that the switch needs to be used. The neutral safty switch has purple, white, and baby blue wire. baby blue and white are cut I believe that they went to the computer which is no longer there. Did the neutral safty switch work through the computer? Help
Old Apr 6, 2007 | 09:30 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
THERE's NO SAFETY IN BEING NEUTRAL
The fastest way, and easiest to restore is to
unscrew the neutral/park switch,
move it to the park position,
hot-glue it so it won’t move.
Tape or tywrap it out of the way.
Happy Racing !
|__|==(_)==|__|
— If people drove any slower
they’d be going backwards —
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
