12V source
Car: 86 IROC-Z
Engine: LB9 5.0 tpi
12V source
I am having to wire up guages. Where can i get a 12v source at? People say the fuse box...what in a fuse box has a 12v source that i can tap?
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Re: 12V source
Personally I think I would wire it up to the guages fuse if you are replaceing the original. If you are adding guages an ohmmeter or a test light will tell you which terminals are key powered. Use any one that's not being used.
Car: 86 IROC-Z
Engine: LB9 5.0 tpi
Re: 12V source
Its just my tachometer. Its an aftermarket tach i bought, and it calls for a 12v fused source with key in the 'on' position. Im guessing i can tie it into ANY source that powers in the on or does it have to be one of the empty slots?
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Car: 89 Firebird
Engine: 350 Ramjet
Re: 12V source
I hate it when the keyboard writes what I tell it instead of what I mean.
I would suggest an empty slot to make sure you have cleaner power less chance of a possible problem later..
Car: 86 IROC-Z
Engine: LB9 5.0 tpi
Re: 12V source
Problem solved guys. I did forget to mention that this is a car with NO dash or console in it. (race car) so i dont have to go to the fuse box. I went straight to the connectors that Used to plug intoo the back of my cluster.
Thanks for the help guys.
-Marcus
-Marcus
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
1Aauto
Sponsored Vendors
Jan 20, 2016 01:01 PM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
