Help with the Hood Light
Old Apr 17, 2007 | 06:01 AM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
Ok before my engine swap my hood light worked fine. Now it won't come on. And I have to charge my battery about once every 2 weeks if I don't drive the car. The bulb is new, and the inline fuse (the one that is closed inside the power wire) is in good shape. What else can I check? Anyone have a diagram?
Old Apr 18, 2007 | 05:11 AM
techno101's Avatar
Car: 1989 Camaro RS
Re: Help with the Hood Light
bump
Old Apr 18, 2007 | 05:20 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Perhaps the mercury switch is broken.
JamesC
Old Apr 18, 2007 | 05:32 AM
techno101's Avatar
Car: 1989 Camaro RS
so what kinda switch is it? Is it located behind the bulb inside the assembly?
Old Apr 18, 2007 | 05:42 AM
JamesC's Avatar
Yes, in the base of the light housing. Bending the housing down a bit "might" get the light to work.
JamesC
Old Apr 18, 2007 | 09:02 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Do you have a good ground on the hood and the light itself? Measure voltage on the metal "lampshade". If you see 12V, it's a ground issue.
Hope this helps.
Lou
Old Apr 19, 2007 | 06:11 AM
techno101's Avatar
Car: 1989 Camaro RS
thanks guys, I'll check that out. I relocated the hood light once due to a strut tower brace but I had no problems with it then. Hope I can get it fixed.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
LittleFranks
Aug 20, 2015 03:55 PM
Omega
Aug 10, 2015 12:46 PM
