insturnment cluster trouble!!!
Old Apr 23, 2007 | 08:08 PM
ShaunZmuders's Avatar
Car: 1989 camaro IROC-Z G92
Engine: GM 355
Transmission: Mad Dog 700R4
Axle/Gears: 3.27 :(
hey, I was wondering if any of you know what I should do. I have a 89 camaro I-ROC and I just put a speedometer cable and gear in the car. the speedometer now works but the other gauges do not. It seems like i installed the insturnment cluster wrong but it all bolted back up. the gauges were working before I put the cable in. could it be the circuit board?, the bulbs still work liek the turning signals and the dash lights just not the rpm gauge oil pressure and engine temp. any advice would be helpful, thanks alot!
Shaun
Old Apr 24, 2007 | 05:28 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: insturnment cluster trouble!!!
Sounds like the cluster's not seated properly.
JamesC
Old Apr 24, 2007 | 06:56 PM
Engine: GM 355
Axle/Gears: 3.27 :(
is there any special way it seats on? Ive taken it out and puttin it back in and so far the oil pressure and the tacometer works but still not the fuel and temp and battery gauge, i replaced the fuse too. could it be a bad connection with that circuit board thing in the back?, is ther any way i could get another one without having to get a whole new insturnment cluster? thanks
Old Apr 24, 2007 | 07:36 PM
strokermotor91's Avatar
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
when you take it out to check it again make sure the copper terminals are seated properly before you push the connector in. I've had the same problem before you're having now. And yes i believe you can get just the circuit board if you need to go that route.
Old Apr 24, 2007 | 08:40 PM
Engine: GM 355
Axle/Gears: 3.27 :(
Thanks, how can u make sure the terminals are seating correctly im not quite sure what you mean, and does anybody have a place where i can get the circuit board from I did a search but couldnt find anything thanks again everyone!
Old Apr 24, 2007 | 10:25 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I had a couple of broken traces on mine. Decided to solder some wire in to splice the breaks. You have to peel the clear plastic from the trace you want to repair, or just melt it away with the solder iron. I also soldered in all of the lugs to keep them from falling out and to ensure good connections to the associated gauges.
Attached Thumbnails insturnment cluster trouble!!!-p1010346-medium-.jpg   insturnment cluster trouble!!!-p1010343-medium-.jpg
Old Apr 25, 2007 | 12:00 AM
Car: 91 Camaro RS
Engine: Small Block
Thats a pretty good idea. I've never really thought of that. It sure beats buying a new circuit
Old Apr 25, 2007 | 03:16 PM
Engine: GM 355
Axle/Gears: 3.27 :(
well i used an ohms meter and the everything checks out okay on the insturnment cluster, maybe i just have to spend more time with it and try to get it seated properly, il let you guys know haha
Old Apr 29, 2007 | 06:02 PM
Engine: GM 355
Axle/Gears: 3.27 :(
i cant get it, does anybody know how much it would cost for me to bring it in a shop and have them look at it?
mrbird
Oct 20, 2015 03:43 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
Lmancha96
Sep 25, 2015 08:11 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
