fire but no juice at injectors.
Old Apr 27, 2007 | 07:41 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i got spark, but i can't get juice to the inj.? i checked the fuses ,they're ok .i used a test light at injector wires and nothing.like i say it's got plenty of spark.i mean its firing.i hooked 12v directly to pump and it ran.
Old Apr 27, 2007 | 10:00 PM
Brads RS's Avatar
Re: fire but no juice at injectors.
The pink wires on the injectors should have 12 volts with the key on. When you say you hooked 12v to the pump and it ran do you mean the engine ran or the fuel pump ran?
Old Apr 28, 2007 | 02:42 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
the pump.
Old Apr 28, 2007 | 05:58 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
The positive side of the injectors should be constand +12v with the ignition on. Check that they do at the plug with the test light between the wire and a chassis ground.. The ecm grounds the other side to fire the injectors. If you put the light across the injector terminals, and they don't flas but have power, the ECM driver is bad or the wire is broken somewhere.
Old Apr 29, 2007 | 04:18 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
everything works on my car,but the injects .i've tried a different ecm and the same thing ,power evrywhere but the injectors. does the f/p relay have anything to do the injectors?
Old Apr 29, 2007 | 08:08 AM
BlueSmoke's Avatar
Car: 91 RS Camro Ttop
Engine: 5.0 LO3
indirect i suppose. hard for injectors to spray gas if the pump doesn't get it to em.
Old Apr 29, 2007 | 09:42 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
never mind ,it won't even turn over now-AGAIN!
Old Apr 29, 2007 | 02:58 PM
Toehead's Avatar
No, not never mind. That problem is still there. Trace back the power from the injectors back into the fuse block. There must be a break somewhere if everything else has power. Did you check the fuses?
Old May 1, 2007 | 06:00 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i checked fuses ,the car turns over good now.but still no juice to the injectors.
RS Reaper
Oct 17, 2018 07:52 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
JSDaddy189
Sep 26, 2015 03:50 PM
indygene
Sep 26, 2015 11:21 AM
