starting pobable cause?
Old May 1, 2007 | 12:04 AM
89_KITT's Avatar
Car: 1989 Pontiac Firebird Mint. cond.
Engine: 2.8L V6
Transmission: factory
Axle/Gears: factory
hey guys i have a quick question. ive been having problems with my starter as well. it starts fine in mornings and stuff but then when i start it after it sits in the sun for about a few hours it wont start. so i was woundering if this was similar to your problems? and if its the vats. (btw the starter is a couple months old nib from auto store)my dad claims the vats is setting it off.i thought i might ask some opinions. and does anone have a diagram for a direct link to starter/toggle or push button? and could i run it threw the vats so it will only be enabled wit the key in the ignition?
recap:
1. starts fine in morning, and most after noons
2. doesnt start in lots of heat
3. starter is fairly new
4.can i wire a vats+key in open= to push button start? or toggle start?
5.volts show that i have 8-9 volts(like a low battery) but then once my car is jumped it starts fine. does this mean its a wire problem/fuse relay? or is it VATS
6. Gaurenteed to start with a jump. (if it was a VATS problem it still wouldnt start wit the jumpstart ? am i right?)
old wiring is
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
