'88 IROC tach needle missing...
Old May 2, 2007 | 05:01 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
Anyone know if you can just replace the needle on the tach in an '88 IROC or even just the tach itself or if you'd have to replace the entire gauge cluster?
Old May 6, 2007 | 12:36 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: '88 IROC tach needle missing...
The needles just pull off of the gauge. Im sure if you put one back on it would work fine.
Old May 6, 2007 | 03:05 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
the needles are removed and replaced easily as stated above, but i'm wondering why it's missing in the first place. did you just buy the car? i'm wondering why it's missing; maybe there is another problem with the gauge that lead to the previous owner playing around with it.
Ducati900ss
Sep 2, 2015 09:05 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
mustangman65_79
Aug 11, 2015 03:17 PM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
