Where is the cluster(gauge lights) fuse?
Old May 4, 2007 | 10:04 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Last night, I was working on hooking up my 4th Gen center console, and trying to get both cigarette lighters to work. I hooked one up temporarily to the gear indicator light (its an auto shift plate. At night, I go to turn on the lights and everything comes on (outside headlights and foglights) but my cluster does not light up. None of it. So I disconnected and undid the cigarette lighter set up, but no luck. I believe I possibly blew a fuse. The reason I believe is because my "Service Engine Light" still works (comes on when the key in the acc position) and my "Brake" light comes on if I engage the e-brake. I looked in the fuse panel and checked every single fuse. And they are all good. I even replaced a couple of "questionable" fuses just in case. There is a spot on the panel, near the top that says "cluster 10". I tried to insert a "10" fuse but there is no metal clips in the spot so I the fuse doesn't go there. Is there something I'm missing? My gauges still work fine, its only the lights that do not come on. Is the light fuse somewhere else? please help if you have any info or similar experience. Thanks.
ps. I did try the "search" option but was not able to find my answers...
Old May 4, 2007 | 05:14 PM
HCR13's Avatar
Car: 1987 Trans Am
Re: Where is the cluster(gauge lights) fuse?
also, I noticed this morning that the "lights are on without key in ignition" beep/alert doesn't beep anymore...
Old Jun 25, 2007 | 11:53 AM
t/adreams's Avatar
Car: '91 Trans Am
Engine: 350 Blueprint Engines Cruiser
Transmission: TKX 5 speed
Axle/Gears: 3:42
I am having the EXACT same problem, minus the 4th gen dash.
My gauges work great, but all the sudden the back lights are out. They don't light up under any circumstance.
Old Jun 26, 2007 | 12:13 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
The insturment lamps are fed from the 5 amp "INST" or "INST LPS" fuse, via the TAIL fuse and the headling switch.
Back Up lamps are fed from the Turn-B/U Fuse, 20 Amp
TAIL Fuse, 20 Amp, feeds the reaminder of the tail lights, except the turn signals, which are fed from the Turn-B/U fuse.
Dave
Old Jun 26, 2007 | 10:18 AM
t/adreams's Avatar
Car: '91 Trans Am
Axle/Gears: 3:42
Dave
Thank you Sir! Headed outside to play now.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
ChevyZ71
Aug 13, 2015 07:30 AM
Omega
Aug 10, 2015 12:46 PM
