CODE 42 HELP!
Old Jun 25, 2007 | 10:09 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
CODE 42 HELP!
my car has a bad mis, poor power, and afew cylinders getting spark but not firing. Bad Ideal ect... been making me nuts! After looking more into code 42 I see it could possible be a bad ecm or ign. modual. Dumb question.. does that mean I need to replace the computer or just the Ign. mod under the car on the distributor????? thanks!
Old Jun 26, 2007 | 11:21 AM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
Re: CODE 42 HELP!
I had a 83 crossfire motor do this yes I know way different year .... 42 was being triggered by a bad magnetic pickup coil in the distributor ..... symptoms the car had were
Bad fuel odor
felt like it was running on 6 to 7 cylinders
used an ungodly amount of fuel as well
this code was in reference to est (electronic spark timing) circuit. I tried new ecm, ignition module, esc module, knock sensor, coil ..... Hope that helps a little. I know your car is alot newer and all but it works the same as my old CFI electronics
Good luck
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
