ECU location
Old May 5, 2007 | 07:28 PM
zachsdad's Avatar
ECU location
I have a 90 rs where do I start looking?
Old May 5, 2007 | 09:43 PM
rhomanski's Avatar
Car: 86 firebird v6,86 corvette,88 GTA
Engine: 350 C.I.,2.8l.
Transmission: th700r4
Axle/Gears: 3:08,3:27
Re: ECU location
The ecm should be in the passenger side dash.
Old May 6, 2007 | 06:46 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: ECU location
Remove the black plastic panel just above the passenger's feet and you'll see a huge wireloom coming up into the dash. The ECU is there, close to the A-pillar, right behind the plastic of the dashboard. Better lie on your back with a flashlight pointed up there because there is a plastic tab that holds the ECU in a plastic cradle.
Hope this helps.
Lou
Old May 6, 2007 | 07:04 PM
zachsdad's Avatar
Re: ECU location
Thanks i found it.
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
6998poncho
Sep 25, 2015 02:56 PM
Nikole
Sep 24, 2015 08:12 PM
tonys91rs
Sep 2, 2015 07:07 PM
